[SOLVED] Power supply question (connectors)
Oct 31, 2020
so i have asus motherboard with 4 pins for cpu but i can barerly find psu with 4 pins that fits my build I keep finding power supplies with 8 pins for CPU, so my question is can i use those with 8 (4+4) pins on my motherboard or do i have to find exactly one with 4 pins
These would be the best options I could find at a reasonable price:
Seasonic Core GC 500W 80+ Gold:
https://www.nabava.net/napajanja/se...easonic-core-gc-500-500-w-100-240-v-106674521
Cooler Master MWE V2 550W 80+ bronze:
https://www.nabava.net/napajanja/co...nze-v2-550-mpe-5501-acaab-eu-cijena-102851671
The Seasonic is the better unit of the two, but the CM is decent as well.
I'll leave this Seasonic Core GM-650 too... it's a bit more expensive, but 650W will give you more headroom for future power hungry upgrades:
https://www.nabava.net/napajanja/na...0-gold-cijena-650w-modularno-80-gold-91615271
Yes, you can split the 8 pin in to 4+4 pin and use it. That's why it can be split in the first place.
Usually PSUs with only a 4 pin EPS connectors are very old or crappy by now.
What are the system sprcifications?
Usually PSUs with only a 4 pin EPS connector are very old or crappy by now.
Specs
Rx 580 4gb sapphire (8 pin)
Asus prime a320m-k (24 pin)
Ryzen 5 1600 (4 pin)
Patriot 2666hz 8gb
WD caviar black 1TB (storage) - switching for a Toshiba one because caviar black produces hella noise and i cant stand it xd
SSD 120 GB (OS)
thanks for answering you saved me a lot of money and time...
Reactions: mirkomirkica
