power supply questions
kfronda26
95
specs:
mobo:GA-F2A85x-UP4
APU:A10 5800k
memory: RipjawsX 1600mhz 8gb (2x4gb)
GPU: AMD Radeon hd 7970 1gb
520w psu enough????
No I wouldn't recommend a 6670 for gaming. A 7970 is fine if you really do want it though. That PSU should be fine for your...
JJ1217
500W would be enough for an unoverclocked system, provided that most of the 500W can be supplied on the 12V rail.
OP, it'll be helpful if you told us what particular model your power supply is, and the amount of amps on the 12V rail before we can give you an accurate assessment. There aren't alot of 520W PSU's on the market, so it sounds like its from Seasonic or Antec to me.
Also, I wouldn't really recommend putting an A10 with a 7970, just seems out of place (Since trinity is mostly bought for its internal GPU).
kfronda26
95
6670 enough? btw the psu is ANTEC NEO ECO 520w
JJ1217
No I wouldn't recommend a 6670 for gaming. A 7970 is fine if you really do want it though. That PSU should be fine for your system.
kfronda26
95
thanks
