Question Power supply recommendation for my system
pell380
701
21
specs :
i5 2500k
cooler master hyper 412 slim
asus p67 sabertooth motherboard
500gb hard disk
128gb ssd
gigabyte gtx 660 2gb windforce oc edition
8gb 1600mhz ram
pc case deciding ( gigabyte c200g or corsair spec 4 or 5)
i need a psu recommendiation for my system i will be overcloking my cpu and a littlie bit of gpu previosuly i had a corsair vs 650 i had a very bad experience with it i need a power supply recommedntion not very high budget ibut it should do the job done and it should be reliable for overcloking i am looking at 550watt pau recommend me
4745454b
A VS650 couldn't handle that load? You have a sub 100W CPU and a GTX660 which is ~120-150W depending on model going from memory. Your gaming load should be sub 300W, which is less than half of what that VS650 could do. It should have handled that load just fine. Any quality 450-550W unit should work. I had a gaming load system running on a Leadex 450W unit. Handled that just fine until my town burned down. (no, the PSU wasn't the reason the town burned down.) What is your budget and location?
pell380
701
21
location pakistan , budget for psu and gpu is 100usd i found a deal at 90$ corsair spec 05 + va 650 brand new should i go for that again ?
