Power Supply Recommendation?
PhilipDM42
Commendable
Dec 23, 2016
20
I've tried checking the forums and Neweggs recommendation checker, but still not an exact answer.
I have:
DeepCool Tesseract Case with 2 Led Fans
GTX 1050 ti
i3-7100
Gigabyte B250M-DS3H MOBO
2 8GB DDR4 2400MHZ
and as far as Hard Drive, I'll be buying one from best buy 1tb, not sure of the specs.
I need to know whether I'll be overshooting the necessary wattage because the only Power supply on hand at my nearest best buy is 750W. I know I should go for 500W, but maybe I don't because CoolerMaster over here is telling me 300W is sufficient.
To receive the right answer, please give detailed information as to how you came up with the answer. Most of the other threads just throw out a number. I'm hoping this thread will help others whenever the search the same question.
I would upgrade, but that'll be in a year or so. I'll go with the 450 from the Senior Moderator
Please give details as to how you guys came up with those numbers too <3.
Cool, thank you.
Question:
I'm currently on a prebuilt PC that is using 250W power supply. I already placed an order on the 450W, but I would like to test my pc.....now. Would you allow someone to use an old Power supply and connect it to the custom built PC?
