Power supply recommendation
Onepilot6
7
Hello members i am going to build a new system and the configuration is as follows :
Cpu Amd a8 7600
Motherboard GA-F2A88XM-D3HP
Corsair 8gb ddr3 1600mhz
Wd 1tb harddisk
Now there are two components
Tagan stonerock 600 watt psu
And powercolor hd 4870 1gb Graphic card.
thease are from my last pc that i hadn't used much so i kept those remaining power supply and graphics card very safe wrapped in a thick plastic sheet in a safe location from last 7 years now i want to use them in this build will it be fine if you think its fine to use them or should i buy new power supply and graphics card please guide me which power supply would be best for my usage i am not going to overclock just gaming.
Kindly help me out.
If you are dead set on using this system instead of upgrading to Ryzen, I would recommend the following.
Keep the PSU if you believe it is good. 600wt is more then enough for this build.
Add an SSD and replace the GPU.
However, don't go crazy on the GPU because CPU and other system components will end up being a bottleneck. But you will need something better then that card for gaming.
