Hey,
I have been getting high power usage on task manager,
Starting to believe its my Power Supply that needs upgrading as my 3D software has been crashing but the memory and CPU are not hitting high numbers so i dont
think its an issue with those.
Even chrome is very high power usage and with Maya (3d) (Vray) open as well i think its just too much for it.
Currently have the below PC spec
Intel Core i7 5960x
Gigabyte X99-UD4-CF Motherboard
DDR4 Ram 32gb
1080TI Graphics Card.
XFX 650 W 80+ Bronze Certified Semi-modular ATX Power Supply. 5 years old.
So do you think i need to upgrade and also, What do you recommend?
Thanks
Intel Core i7 5960x
DDR4 Ram 32gb
Thanks
