Power Supply Voltage Readings in Speedfan, should I be concerned?
MrJak
274
I have these readings showing, and want to make sure if I should be worried about this:
Try the freeware HWiNFO64. Download it from here: http://www.hwinfo.com/download.php
The Portable version doesn't install anything onto your system whereas the Installer version is like installing any other application.
I can't guarantee that it will work with your specific system because I didn't see the nForce 790i Ultra SLI chipset on its Chipset support list, only the nVidia nForce 720i/730i/740i/760i SLI, GeForce 9xxx (MCP79/7A), ION, MCP89 are listed. If the sensor chip on your motherboard is supported then there's a great likelihood that the voltages will be correctly displayed.
You just need to use a better utility. One that actually understands the signals from your motherboard's sensor chip.
Use the utility that came with your motherboard or download a more recent version of it from the motherboard manufacturer's web site.
If your PSU's +12V rail were really outputting 10.88 Volts your system wouldn't even be running.
That's what I figured, especially when I've been playing games.
However, I don't know of any software like that for this motherboard?
Okay, this looks better, but I thought I'd check:
Well, Speedfan shows that to be about right, and the rest is good, so I probably have nothing to worry about, right?
By the way, thanks for the help! 😀
Okay. Thanks again! 😀
