F FuDgE Distinguished Apr 24, 2009 27 0 18,530 Jun 24, 2009 #1 hi with graphics card power supply cable do you have to plug both plugs into the power supply or just one?
505090 Distinguished Sep 22, 2008 1,575 0 19,860 Jun 24, 2009 #2 if the card has two plug then it needs to plugs
F FuDgE Distinguished Apr 24, 2009 27 0 18,530 Jun 24, 2009 #3 i have a nvidia 9600 gt. it has got two power supply connecters on one end.
Twoboxer Splendid Jan 21, 2008 4,208 0 23,460 Jun 24, 2009 #4 if the card has two plugs then it needs two plugs.
505090 Distinguished Sep 22, 2008 1,575 0 19,860 Jun 24, 2009 #5 o the adapter my mistake then you only need to use the one the other is a pass thorough to power another device which you shouldn't do anyway
