Power supply
zallidor
fan keep runing after new install. this is a 400w coolermaster. Installed in a Hp pavilion a6700w stock . no work load idle state. did have a minnor issue with the mobo connect 20/24 pin set up . 4 pin came loose . would like to se if there is any other input on this issue.
If it is like that, its OK. BTW the 4pin has 2 teeth to lock with 20pin to make 24pin.
well the p/s was working fine and then the pc stops working . I went into the case re-seated the mobo cables starts up fine than stops working reseat the connectors agian works fine , got a call today not working agian . me think its mobo any ideas
Is it pushed in all the way?
Hp pavilion a6700w stock. had a 300 watt replacement is a 400 w . so 100w more then spec.
Processor
AMD LIVE!™ Made to Bring It All Together
• AMD Athlon™ 64 X2 Dual-Core Processor 4200+
• 2.2GHz, 512KB+512KB L2 Cache
Operating system installed
Genuine Windows Vista™ Home Premium
platform
Chipset
NVIDIA nForce 430 Chipset
Standard memory
1024MB
Memory type
DDR2-SDRAM
Memory slots
4 DIMM (184-pin, DDR2) (two available)
