[SOLVED] Power switch wiring
ArcanumSteamwork
23
Hello, I am building a custom case without a front panel and the power and reset buttons will be integrated into the desk.I bought the momentary stitch in the photo but I can't figure out the wiring, it will need only the power SW and Led+/Led- connectors.
I found another similar post where they were saying that it is not possible to use this switch but I found other switch buttons that look identical to mine (second picture).
Assuming your original pic is of the actual momentary switch....
Connect the two wires to C and NO.
Pushing the button makes a connection. Releasing the button goes back to NO (Normally Open)
No datasheet is available for the button, it is a normal switch with NO, NC, C, L+, L- terminals but I don't understand where I need to solder the cables of the Led+/- and power sw pins. This is basic electronic but I have never studied it.
NC == Normally Closed
NO == Normally Open
Neither of which have anything to do with the power button for a PC.
Is this a momentary switch?
Link to where you bought this?
