G
Guest
Guest
Hey all,
Intel WS440BX md (Gateway OEM, actually)
Intel PIII 600 (non-coppermine)
256 MB SDRAM (non-ecc, unbuffered)
ESS Integrated audio, 1373 Chipset
Adaptec 3940U2 SCSI adapter (Gateway OEM)
3com 3C509B-TX Ethernet Adapter
Supermicro SC-750A Case w/300W powersupply
HP CD-Writer 8100 (Primary IDE1)
Toshiba DVD SD-M1212 (Secondary IDE1)
Mitshubishi LS-120 drive (Secondary IDE2)
Iomega Zip 100 (Primary IDE2)
Quantum Atlas III LVD 18 GB SCSI drive
Quantum Viking II LVD 9.1 GB SCSI drive
Mitshubishi CM813U 21" Monitor (Gateway OEM)
*and*
Visontek GeForce256 (nv10) w/32mb DDR memory
running on MS Windows 98SE.
THE ISSUE:
The system seems to run fine until I do something graphic intensive, such as run Unreal Tournament. Then the system will freeze such that sending ctrl-alt-del from the keyboard will reboot but nothing else causes any system reponse what-so-ever. I am pretty confused and lost as even scaling back the resolution and color depth does not seem to help matters. The graphics adapter works great in a friends Gateway/Fedora system.
Anyone, any thoughts?
Regards,
Gus
*and*
THE ISSUE:
Regards,
Gus
