F Fanax Honorable Apr 5, 2016 65 1 10,545 Sep 7, 2020 #1 Hi, One fan started making grinding sounds louder and louder in last couple of months. Does anyone know if these fans are serviceable? Is it possible to just pop up the fan and lubricate it? Or do I need drill a hole?
Solution bishopi5 Sep 7, 2020 What brand card is that ???? Yes for the most part all fans are removable, its just a cooler connected to your card, you would have to remove the cooler to get access
bishopi5 Distinguished Dec 12, 2012 971 20 20,015 Sep 7, 2020 Solution #2 What brand card is that ???? Yes for the most part all fans are removable, its just a cooler connected to your card, you would have to remove the cooler to get access Upvote 0 Downvote Solution
F Fanax Honorable Apr 5, 2016 65 1 10,545 Sep 7, 2020 #3 Model number AXRX470 4GBD5-3DHDM . Upvote 0 Downvote
