Hello Everyone,
This is my first post, please forgive any mistakes or errors.
Mobo - Asus Tuf z490 plus with {WiFi 6 antenna)
Ethernet - Cat5e cables
Powerline - TP=Link PA717 AV1000
Connection - Virgin Media 100mbps - Hub 3.0
Questions : Is there a reason there is a 5x difference in download speed, Powerline being the slower?
Do a lot of people switch between powerline and wifi for gaming and downloading for stability vs download speed?
I have taken into account:
I tested my macbook pro 2017 and got the same WiFi speeds as above, can't test it via cable though as do not have the outputs.
Hub is downstairs, PC is upstairs. They run on the same electrical network. I cant seem to see why there is such a huge discrepancy but I have read that powerline can be hit and miss. Ultimately wondering if I should just send the powerline adapters back if its not worth having.
Any insight would be appreciated.
Thanks
- Powerline speeds depend on the circuitry
- Powerline is generally more stable with lower latency (although pings seem to be very similar) and less interruptions when it comes to gaming
- Gaming does not use a lot of bandwidth, so I can switch between the two types of connections if needed, but I'd rather not (annoying)
- There is no way to directly connect with an ethernet cable as it is too far.
Thanks
