Pre-Built Gaming PC (Mainly For CS:GO) Around 800 Dollars That Can Run Max Settings Around 300 FPS?
The_Chicken_McNugget
Commendable
May 23, 2016
21
Hello! The Title Says It All. Note that I need a PRE BUILT, and so I don't want any "Build it yourself" stuff. <MOD EDIT: Language and abusive tone>
That aside, please send me a link or something with details and preferably a written experience and review of this product. I will buy a keyboard and mouse + monitor separately I also need a operating system pre-programmed, preferably not windows 8.
-Deep Regards: The Nugget
Seriously that pc is a joke. Dont buy that.
You may not want to hear it, but building your own PC is the way to go. You will get more bang for your buck. The link posted above is a perfect example. Here is what $800 could get you if you were willing to build it yourself:
CPU: Intel Core i5-6400 2.7GHz Quad-Core Processor ($179.99 @ SuperBiiz)
Motherboard: ASRock Z170M Extreme4 Micro ATX LGA1151 Motherboard ($101.98 @ Newegg)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory ($49.99 @ Newegg)
Storage: Kingston HyperX Fury 120GB 2.5" Solid State Drive ($37.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($47.49 @ OutletPC)
Video Card: Asus Radeon R9 390 8GB Video Card ($259.99 @ Micro Center)
Case: Phanteks Enthoo Pro M ATX Mid Tower Case ($54.99 @ Newegg)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($74.99 @ SuperBiiz)
Total: $807.41
Generated by PCPartPicker 2016-06-08 13:11 EDT-0400
It can seem daunting to build your own PC, but if you take your time and do some research beforehand, it really is not all that difficult. You dont need anti-static wrist straps or any of that nonsense either, just dont build on carpet, touch the case often, use some common sense and it will be fine.
If you're still stuck on buying pre-built, just buy the one that was posted. Keep in mind that you're paying for crappy components though.
Here: http://www.cyberpowerpc.com/saved/1HYKW3
Intel i3 SFF Configurator (NO MONITOR) said:
*BASE_PRICE: [+509]
BLKFRISALE1: CYBERPOWERPC Skorpion K1 Mechnical Gaming Keyboard w/ Kontact Blue Switches and Programmable Blue LED Lighting [+0]
BLKFRISALE2: CyberPowerPC AULA Explosive 50mm Drive Analog Gaming Headset [White & Orange] [+0]
BLUETOOTH: None
CABLE: None
CAS: Raidmax Hybodus mATX Gaming Case
CD: None
CPU: Intel® Core™ Processor i3-6100 3.70GHz 3MB Intel Smart Cache LGA1151 (Skylake)
DOCKINGSTATION: None
ENGRAVING: None
ENGRAVING_MSG:
FAN: Intel Certified CPU Fan & Heatsink [-27]
FREEBIE_CU: None
FREEBIE_HD: None
HDD: 250GB Samsung 850 EVO Series SATA-III 6.0Gb/s SSD - 540MB/s Read & 520MB/s Write [+43] (Single Drive)
HDD2: None
HEADSET: None
HS_HANGER: None
KEYBOARD: None
MEMORY: 8GB (4GBx2) DDR4/2400MHz Dual Channel Memory (Corsair or Major Brand)
MONITOR: None
MOPAD: None
MOTHERBOARD: ASRock H110M-ITX/AC Wi-Fi, GbLAN, w/ USB 3+ 4X SATA 6GB/s 1 Gen3 PCIe x16
MOUSE: CyberpowerPC Standard 4000 DPI with Weight System Optical Gaming Mouse
NETWORK: Onboard Gigabit LAN Network
OS: Windows 10 Home (64-bit Edition) [+104]
OVERCLOCK: No Overclocking
POWERSUPPLY: 550 Watts - XFX TS Series 80 PLUS BRONZE Certified Power Supply [+20]
PRO_WIRING: None
RUSH: Standard Process Time: Ship within 7 to 12 Business Day
SECURITY: None
SERVICE: STANDARD WARRANTY: 3-YEAR [3 Year Labor, 1 Year Parts] LIMITED WARRANTY PLUS LIFE-TIME TECHNICAL SUPPORT
SOUND: HIGH DEFINITION ON-BOARD 7.1 AUDIO
SPEAKERS: None
TUNING: None
USBHD: None
USBX: None
VIDEO: EVGA Superclocked GeForce® GTX 950 2GB GDDR5 (Maxwell) [+130] (Single Card)
_PRICE: (+779)
_view_: {919AD93D-D7FB-4176-86FA-C2BBC4DB1F73}
_load_: 6/8/2016 10:45:09 AM
Hmmm.. Which One Posted? The i3 SFF or The Other One. Note that I need a Operating system too.
The NEX 650G is a poor quality power supply (group regulated). Also, an I5-6500 is much better price/performance, and there is no reason to get a Z170 motherboard with a non-K chip. I'm also not sure about the SSD. 250GB is the norm, and I'm unsure how good of quality it is. Samsung is probably better price/performance, even if it is a bit more money.
The first one isn't a prebuilt, mine is, and it includes an OS. (and a keyboard and mouse and headphones/set)
He clearly said $800. Obviously the i5-6500 is better, but it would put the cost way over the budget. Also, the z170 is more future proof. Sure he could go with a cheaper h110 or something but then to upgrade to an 1151 socket processor he'll need to change the mobo too. All of the parts could be tinkered with, the point of posting the list was so that he could see how much better a custom built PC would be compared to something pre-built.
an i3 is weak for gaming. Look for i5 or better.
for starters, streaming goes out the window with an i3. Again, I was trying to give the man a more future proof option. If all he cares about is playing csgo and nothing else, an i3 will be fine, but It's foolish to think that in 2 years that prebuilt system will be any good for anything OTHER than playing csgo. Games are starting to use more cores now and it's not like the technology will regress.
Streaming is totally possible with an i3, you just have to know your limitations.
You don't know what you're talking about, and you made it abundantly clear when you failed to properly identify what an h110 motherboard can do.
Do you think I can get a i3 6100 with the GTX superclocked 750ti and a Windows 10 operating system? would that work well for CS:GO?
I won't be playing most of the new games, just OSS games like TF2, CS:GO, (HL3 I wish) and Stuff like that.
The First One doesn't work anymore, check it.
It still doesn't have an operating system
Now it does: http://www.cyberpowerpc.com/saved/1HYR29
(You could have added it yourself)
