Prime95 overclocking 8320 problems please help.
Skreedles
119
While running prime 95 I've come across two types of errors in one it says
error 1, warnings 0. Messed up on rounding from 0.4-0.5
The other error I got resently was
error 0, warnings 100
Also while running prime 95 I've noticed one of my cores is typically slower than the others and "fails" first.
DonQuixoteMC
What are your OC settings?
What temperatures are you getting?
Skreedles
119
MY Cpu ratio multiplier is at 21.5 I believe, whatever makes it go to 4300mhz
and my vcore (the top offset one is at ~1.32 which equals to 1.41 volts and my temps are at socket: 67 Core 49.
Skreedles
119
