Print problem with Edge
Oldtreker
16
Hello,
I have been using Edge for the past few months exclusively. I have a print issue, thought it was the printer. Turns out the Edge interface seems to be the problem. Using Edge, a black box appears with lots of options, if you just print the fonts are too small and using a multifunction printer it switches the paper tray to the photo paper. I have the option of changing the settings but must do it every time I print.
I do not have this problem using Firefox or Chrome which still use the previous printer interface. Canon support says it an Edge issue. However, I did notice a different print menu using Edge on my Dell Desktop compared to my dell laptop, the desktop
Doesn't have the LETTER SIZE option default listed rather it says 4X6. The laptop shows the LETTER SIZE listed automatically. I have attached two photos to compare
Dell Inspiron upgraded to windows 10
Canon Printer MX922
http://
http://
Deleted all the printer software and drivers completely, reinstalled it all. Problem solved. I guess the glitch occurred during the download and install of windows 10.
Thanks for the replies. Problem was solved when I updated the drivers from Canon
