Problem Adding 2nd DC to domain
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Archived from groups: microsoft.public.win2000.active_directory (More info?)
W2003 Enterprise Domain Controller
using Simple DNS plus
Attempting to add 2nd W2003 DC to domain
using DCPROMO get to enter user password to add server to domain get
following error
An Active Directory Domain controller for the domain xyz.xxx could not be
contacted.
In the help window is the following
DNS was successfully queried. for the service location (SRV) resource record
used to locate a domain controller for domain xyz.xxx
All the A records SOA and SRV records are correct on the DC.
nslookup shows correct dns resolution of DC to ip address
set q=a resolves correct FQDN
both servers can ping the FQDN of each other
I cannot install Active Directory on the 2nd DC or join the domain
Any help is appreciated.
Kevin Paulus, CCNA, MCP
I believe it is looking at the DNS you have supplied and is unable to find
the AD service records. Are you pointing to the same DNS server as the
current dc is pointing to?
Paul Bergson MCT, MCSE, MCSA, CNE, CNA, CCA
This posting is provided "AS IS" with no warranties, and confers no rights.
"kp" <kpaulus@povn.com> wrote in message
news:RfudnUOpkMDjSV_fRVn-iQ@povn.com...
> following error
> contacted.
> record
The DC is pointing to itself as DNS, as it is on a nat subnet and does not
resolve traffice to my ISP. I forward the zones to my ISP to resolve one
machine that is on a DMZ port on my firewall.
The 2nd DC is pointing to the DC for DNS.
Kevin
"Paul Bergson" <pbergson@allete_nospam.com> wrote in message
news:%23mdql1MfFHA.3916@tk2msftngp13.phx.gbl...
rights.
> > following error
be
> > contacted.
> > record
In the DNS log on the DC, when trying to join the domain the following entry
is given when replying to requesting client.
No A - records available for xyz.xxx (domain)
Kevin
rights.
> > following error
be
> > contacted.
> > record
You should have a xyz.com domain with the following for sure:
_msdcs sub-domain
_sites sub-domain
_tcp sub-domain
_udp sub-domain
DomainDnsZones (2003)
ForestDnsZones (2003)
The above contain the service records for your AD
Type = Start Of Authority DCxx.xyz.com
Type= Name Server (NS) DCxx.xyz.com
Host(A) = ip address of your DNS server that Holds the Dc
All your host records for your xyz.com domain
There are either problems on your current DNS that hosts your dc (You could
try netdiag /fix but I doubt this is the problem) or there is a
communication problem/configuration error. Is there a firewall problem
between the two?
news:l-adnUcmY4l2fF_fRVn-2Q@povn.com...
> entry
> Kevin
>> find
> rights.
>> > following error
> be
>> > contacted.
>> > record
