Problem, after replacing CPU stock cooler to Xilence
beckham9
27
Ok, here is the main problem:
PC turns on and then nothing happens - black screen after motherboard screen. And if i try push DVD - ROM key there is a mechanical sound and DVD ROM wont open.
I think it is curve_hand.dll and there is something in SATA connectors.
Help, pls.
Make sure everything is connected properly.
beckham9
27
I have 2 colours to SATA Connectors - Red (SATAII -1 and SATAII -2) and Orange (SATAII-3 and 4).
Where I need to connect DVD connector and HDD connector?
I just plug in my SATA connectors regardless and they work. As long as it's SATA-to-SATA it should work, but I would recheck to see that all your cables are seated in and not loose.
beckham9
27
As I see everything is ok in connections.
beckham9
27
Ok, now it shows me BOOTMGR error. Just need some Windows installation and I''l be ok.
Can I use the old one HDD (who failed) as an external drive for pictures or smt?
If a drive failed then it would have a problem even running to store pictures, just use a different one or buy another one.
