Have an Alienware X51 R1 with 330 power brick with intel i5 with 16 gb ram , 1 tb ssd drive , windows 11 home with nvidia 1050ti 4gb gpu. I was looking for extra gpu vram so I installed nvidia 1060 6gb gpu.
However, I have issue where windows 11 device manager doesn't see the 1060 gpu and nvidia control panel doesn't see it either.
I reseated it 6 times. made no difference, i plugged into the two different 6-pin connectors to gpu, made no difference. i unplugged the 6-pin connector to see if pc would say something and in dos boot up , it said to plug in power cable to nvidia gpu card so dos see it but not windows.
I have the lastes bios A14. only difference between the 1050 ti gpu and the 1060 gpu is the 1050 ti doesn't require or has 6 pin power connector where as the 1060 needs 6 pin power connector and has 6gb ram where 1060ti has 4 bg ram. any ideas or has only came across this and ow did you fix. would getting R2 D85RT power board make any difference . cheers
