[SOLVED] problem back after 5 month
Jan 21, 2019
4
automatic Repair Couldn’t Repair Your PC on Windows 10 its the 3 tims its heppans in 1 years
i try to fix it by chkdsk its start to fix and stop and said cannot not have enough memory
and i try to fix the problem too by bootrec /fixboot with all commnad but nothing help
the computer with ssd i check bad sector its found 1 sector and fix it
here the files of my srtTrail.txt
Startup Repair diagnosis and repair log
Number of repair attempts: 1
Session details
System Disk = \Device\Harddisk0
Windows directory = D:\Windows
AutoChk Run = 0
Number of root causes = 1
Test Performed:
Name: Check for updates
Result: Completed successfully. Error code = 0x0
Time taken = 0 ms
Test Performed:
Name: System disk test
Time taken = 0 ms
Test Performed:
Name: Disk failure diagnosis
Time taken = 47 ms
Test Performed:
Name: Disk metadata test
Time taken = 125 ms
Test Performed:
Time taken = 47 ms
Test Performed:
Name: Target OS test
Time taken = 0 ms
Test Performed:
Name: Volume content check
Time taken = 63 ms
Test Performed:
Name: Boot manager diagnosis
Time taken = 0 ms
Test Performed:
Name: System boot log diagnosis
Time taken = 0 ms
Root cause found:
Boot critical file d:\boot\resources\custom\bootres.dll is corrupt.
Repair action: File repair
Result: Failed. Error code = 0x2
Time taken = 1046 ms
Hey in the file log where you see it can you mark it to me
The power supplier its very chaep and make noise mybe this too can send electric to ssd and make problem to memory
