Hello, it is the first time that I post here.
I bought the PC in 2016, these are my components:
This happened to me once a few months ago but it solved itself but it seems now permanent.
When the computer is on and I touch the two pipes that go from the heatsink to the radiator, one is cold and the other hot.
I have tried to change the thermal paste again, put windows in economic mode and nothing.
I wonder if the problem is in the cooling or in the CPU itself.
Thank you very much in advance!
- CPU: i7-6700k (never overclocked)
- GPU: GTX 1070
- Cooler: Enermax liqmax ii 240
- Motherboard: Maximus VIII Hero
- Open the PC
- Clean all the dust from inside, the fans and the radiator cooler
- Change the thermal paste using the center point method
- Clean the bios cmos
- Update bios version (same config as before)
- Install windows 10 and all drivers
- All fans work correctly
