Problem installing dell desktop system software
JLGodshall
problem installing dell desktop system software on an XPS/Dimension. I run setup, the Installation wizard starts, it does it\'s thing, I reboot and I don\'t see it anywhere. It\'s not in my programs list, no icon on the desktop, and when I look in the destination folder, the only exe file I see is Setup. Any thoughts?
@JLGODshall
do dis first go to start > run > services.msc
find dis "DCOM server process launcher" duble click on it go to general tab
check start up typ n if it will b disable den change to automatic n aftr start service status aftr reboot ur pc den try to install ur softwere
