Problem installing driver component.
ishaankaushik
BANNED
Sep 7, 2017
133
I am trying to install radeon driver 19.9.1 for my RX 460 video card. I am getting a error in events viewer with code 0xC00000E5 for amdkmdap. It says that amdkmdap had a problem starting. I have tried turning off windows security services using regedit and my Avast antivirus. Also I do not have any comodo products and AVG antivirus.
I have disabled all virus and services which I thought may conflict. I still receive the error. Also I have disabled DEP. Do you know of anything else which I should turn off ?
DDU did not work for me. Also one more thing I noticed is that there are two components with same oem.inf number and one of them is amdkmdap , the one I receive error for. This may be the cause. Is their any registry edit that I can try?
I figured out that it was normal to have two oem names for one component. Now will you please do one thing? I want you to check your events viewer (If you have an AMD card) and check for same error , maybe it is an issue with amd driver about which we should report it to them.
