Question problem mobo Asus m5a97 le 2.0
Mar 4, 2021
Hello everyone!
Basically the other night I go to shut down my PC (clean shutdown)
In the morning I go to turn it on but: only the fans turn, the screen is all black and it doesn't even make the BIOS "beep", which I always have to go to in the BIOS to select which HDD to start the PC with.
I must say that I have tried them all .. I also started the MOBO without any USB attached, without RAM, without video card, I replaced the battery, tried a new power supply, switched on outside the case .. but nothing. I just don't understand how this happened and
Before declaring my motherboard dead ..
what else can i do?
Maybe it's a short circuit?
Thanks in advance :)
You might try redoing the thermal paste under the north bridge and south bridge chips as well as the CPU. I was using an ASUS motherboard of that age until recently and doing that gave me another couple of years use of it.
Everything else was fine so I finally just replaced the mobo and it's still running today for my secondary computer in the garage. The mobo was less than $100.
Posso provare a rimettere la pasta termica 😀 anche se ormai sono quasi convinto che non risolva il problema ...
Conosci una buona scheda madre ddr3 compatibile con il mio CPU AMD FX 8350 socket am3 +?
