Hi, So I am installing an MSI z270 m7 board with an intel i7-8700K cpu and corsair ddr4 memory (2x8gb), all parts are brand new.
The motherboard will flash with power and turn off after 1 second, fans will spin and turn off as well. No beeps at all. I have a little portble Antec power supply tester that shows that the PSU is working fine but I tried booting with a second PSU anyway and still same results.
I then took the motherboard out of the case and connected only the cpu heatsink which is an astek 510lc and the PSU while trying to post with only 1 stick of memory. Tried the ram in each dimm slot and with each stick of ram and got the same results.
Im fearing the issue is the motherboard at this point but just wanted to see if there is anything else I am forgetting to check or if anyone has any ideas. Thank you
