Problem on startup
Matt McQ
13
Okay, so I just about finished building my first computer thanks to the support of this community, although when booting up for the first time, I encountered this message, "USB device over current status detected will shut down in 15 seconds". I read on the forums and couldn't really find an answer. I made sure the pins in the USB ports were not touching or damaged. The computer boots up fine and all (case, cpu, and gpu fans all run), but I can not figure out why this is happening? Any help would be greatly appreciated. I can take pictures of things that anyone wants to look at and see. Thank you very much for your help!
Edit: I took all the components out of the case and ran an external build, everything ran perfectly, but when I put it into the case something is going wrong. If anyone has any suggestions at all i would greatly appreciate them
