Problem reinstalling XP - languages
Mar 14, 2018
19
I just reinstalled XP, but it's service pack 1. It won't allow me to access internet even though I have the driver for devices and the Service Pack 3 update won't run since "my computer isn't same language." Also I can't access the "drivers and utilites" disc since it requires Service Pack 2. Help
I'm trying to restore a old PC to run XP. I don't intend to use it to surf the web.
You mean when Device Manager shows the Ethernet devices as yellow question marks? I used this factory driver and utility disc that helped the device manager recognize them.
Yeah yellow question marks are bad in the device manager.
Find the model of your computer and download the most up to date drivers from the manufacturer's website and place it on a flash drive.
Bring the flash drive to the old computer and run the driver update.
Having said that Windows Xp is highly insecure and any computer that came with it is now out of date hardware wise.
I'm thinking its a single core pentium 4 ... or worse.
Even a $300 computer from Walmart would be faster
I said the issue had been dealt with and Ethernet Device is responding on the network connections and the network adapter appears fine.
Nope. I click Internet connection, it tells "connecting" and then says "unable to connect." And that's it.
The ethernet device seems to recognize the correct IP.
Processor: Intel(R) Pentium(R) 4 CPU 2.93GHz (2 CPUs)
It's a old tower PC I'm trying to get run XP for sakes of running XP. It's definetly not my main working computer.
That's odd but unsurprising. I'm thinking you may not have a choice but to see if you can find SPs 2/3 on the web and burn them to disk. I'm pretty sure I had to do something similar when I built a new rig for my mom and had to install XP since I didn't have a copy of 7+ to give her.
I would still download the latest Ethernet drivers from the manufacturer's website.
The fact that device manager is showing a yellow question mark and you are unable to connect still points to a lack of correct Ethernet drivers.
You do apparently have something of an Ethernet driver, enough to populate the Ethernet connections with a generic driver.
But as you can see it isn't connecting.
If once you have the latest Ethernet drivers and it still doesn't work then we can move from there.
You might as well update all drivers; Motherboard drivers, Video drivers, ... once you get Ethernet working.
