Problem restoring Active directory using server 2003
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Archived from groups: microsoft.public.win2000.active_directory (More info?)
Hello all,
I am restoring Active Directory on a 2003 server. I would activate the
server CD key before running dcpromo just to make sure the servers
license is clear. Once I install active directory, restore it from the
BAK file, and reboot the server. I get an error upon login stating
that windows must be activated in order to log in. The original bak
has been activated for over 6 months. I have reinstalled server 2003
serveral times and even ran this on a trial version but I get the same
error message. This restore is only for test purposes therefore I
cannot put this on my public network. Any ideas?
Posted using the http://www.windowsforumz.com interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: http://www.windowsforumz.com/Active-Directory-Problem-restoring-server-2003-ftopict347403.html
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.windowsforumz.com/eform.php?p=1091574
When restoring, are you booting into Directory Services Restore Mode? You
should be.
How old is the backup that you are trying to restore?
Paul Williams
http://www.msresource.net/
http://forums.msresource.net/
> Restore Mode? You
> should be.
> Paul Williams
Hi,
Yes I am booting into directory service restore mode, and my backup is
less than a week old. The 2003 server has been activated for over 6
months now...It’s puzzling
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.windowsforumz.com/eform.php?p=1093107
> Restore Mode? You
> should be.
> Paul Williams
Hi,
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.windowsforumz.com/eform.php?p=1093108
