[SOLVED] Problem setting the dGPU for gaming ?
jalinvul
36
Hi, recently bought a gaming laptop for when I travel. I am having problems getting the dGPU to be used for my games. To get it to work I have to go to Nvidia control panel and set the games to the global settings to use the GPU, but everytime I shut down I need to repeat this again on next start up.
what make/model laptop?
Sounds like its probably got a program that runs with startup that is changing that setting.
Try a clean boot and see if it changes anything - make sure to read instructions and make sure NOT to disable any microsoft services or windows won't load right - https://support.microsoft.com/en-au/help/929135/how-to-perform-a-clean-boot-in-windows
It doesn’t delete anything, it just stops non Microsoft programs running with start. Easy to reverse.
if clean boot fixes it, it shows its likely a startup program. You should, over a number of startups. restart the programs you stopped to isolate the one that is to blame.
Reactions: stonecarver
Acer Nitro 5 17.3in i7 16GB 1TB RTX4050​
