H Harshilvijay Reputable Mar 26, 2014 132 0 4,680 Jun 18, 2014 #1 I recently OCed my Intel 3ghz dual core e5700 to 3.3 ghz and everything ran fine but after rebooting the PC it again shows the old frequency even after OCing,and the date and time also keeps changing
Solution saint19 Jun 18, 2014 That date and time changing tells me that you CMOS battery is ending his life, I would suggest buy another one on amazon: http://www.amazon.com/Energizer-2032-Battery-CR2032-Lithium/dp/B0042A9UXC/ref=sr_1_1?ie=UTF8&qid=1403114722&sr=8-1&keywords=cr2032 Check in you mobo but should be the same model.
saint19 Polypheme Mar 20, 2009 15,746 27 60,540 Jun 18, 2014 Solution #2 That date and time changing tells me that you CMOS battery is ending his life, I would suggest buy another one on amazon: http://www.amazon.com/Energizer-2032-Battery-CR2032-Lithium/dp/B0042A9UXC/ref=sr_1_1?ie=UTF8&qid=1403114722&sr=8-1&keywords=cr2032 Check in you mobo but should be the same model. Upvote 1 Downvote Solution
Snipergod87 Splendid May 26, 2009 5,584 2 29,965 Jun 18, 2014 #3 AFAIK all motherboard use CR2032 battery's for the CMOS. As saint19 said you will need a new one. Upvote 1 Downvote
