[SOLVED] Problem understanding RAM memory
123malstrom
68
Hi Freinds
I am having trouble understanding RAM . I use CPU-Z on my computer and learn that I have 800 Mhz speed ram sticks. But the mobo bus speed is only running at 200 mhz. AMD chip. I did read that "something" is effectively cutting the Ram Stick speed by half. my DRam Timing is running 334.8 Mhz ddr2 sticks.... I am still confused at what device is the bottle neck on speed ... the Board bus speed to the Northbridge or the CPU itself.
Than the the BIG question how do I understand a Boards speed without CPU=Z software. How to understand the online spec's> ??
Much thanks!
First you must understand DDR (Double-Data Rate). Let's say you have DDR2 800. Since RAM is DDR it transfers data on both the on and the off portion of the cycle. So we can say that the speed of transfer is doubled from the frequency of the on/off cycle, hence the "DDR". So DDR2 800 memory would show a frequency of 400MHz, which is a measure of the on and off fruequency. We often call it 800MHz to make it easy; however, 800MT/s (Mega Transfers per second) would be more accurate since the on/off frequency is 400MHz but the data transfer frequency is 800MT/s.
Now, if you say your memory shows 334.8MHz, that would be 333MHz (the bus doesn't always operate at the exact frequency), then you are operating at DDR2 666. There is a reason it...
Now, if you say your memory shows 334.8MHz, that would be 333MHz (the bus doesn't always operate at the exact frequency), then you are operating at DDR2 666. There is a reason it is doing this, but without more information I cannot diagnose why.
Please list full system specs, including motherboard and how many and of which spec memory modules.
Please list full system specs, including motherboard and how many and of which spec memory modules.[/quotemsg]
Primarily I want to buy a new Mobo Cpu and Ram. and I dont want to make a mistake on buying a pinto mobo and a ferrari CPU.
CPU-Z TXT Report
Binaries
CPU-Z version 1.87.0.x64
Processors
Number of sockets 1
Number of threads 4
APICs
Socket 0
-- Core 0 (ID 0)
-- Thread 0 0
-- Core 1 (ID 1)
-- Thread 1 1
-- Core 2 (ID 3)
-- Thread 2 3
-- Core 3 (ID 2)
-- Thread 3 2
Timers
ACPI timer 3.580 MHz
Perf timer 2.551 MHz
Sys timer 1.000 KHz
Processors Information
Socket 1 ID = 0
Number of cores 4 (max 4)
Number of threads 4 (max 4)
Name AMD Athlon II X4 620
Codename Propus
Specification AMD Athlon(tm) II X4 620 Processor
Package Socket AM3 (938)
CPUID F.5.2
Extended CPUID 10.5
Brand ID 8
Core Stepping BL-C2
Technology 45 nm
TDP Limit 96.9 Watts
Core Speed 803.5 MHz
Multiplier x Bus Speed 4.0 x 200.9 MHz
Base frequency (cores) 200.9 MHz
Base frequency (ext.) 200.9 MHz
HT Link speed 2008.8 MHz
Stock frequency 2600 MHz
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V
Microcode Revision 0x1000086
L1 Data cache 4 x 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache 4 x 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size
Max CPUID level 00000005h
Max CPUID ext. level 8000001Bh
Cache descriptor Level 1, I, 64 KB, 1 thread(s)
Cache descriptor Level 1, D, 64 KB, 1 thread(s)
Cache descriptor Level 2, U, 512 KB, 1 thread(s)
FID/VID Control yes
FID range 4.0x - 13.0x
Max VID 1.400 V
# of P-States 4
P-State FID 0xA - VID 0x0C - IDD 19 (13.00x - 1.400 V)
P-State FID 0x3 - VID 0x14 - IDD 15 (9.50x - 1.300 V)
P-State FID 0x10C - VID 0x1C - IDD 13 (7.00x - 1.200 V)
P-State FID 0x100 - VID 0x22 - IDD 10 (4.00x - 1.125 V)
Package Type 0x1
Model 20
String 1 0xA
String 2 0x6
Page 0x0
CmpCap 4
ApicIdCoreSize 4
TDC Limit 76 Amps
Boosted P-States 0
Max non-turbo ratio 13.00x
Max turbo ratio 13.00x
Max CPU COF 26
Core Performance Boost no
P-State 0, FID 0xA - VID 0x0C (13.00x - 1.400 V)
P-State 1, FID 0x3 - VID 0x14 (9.50x - 1.300 V)
P-State 2, FID 0x10C - VID 0x1C (7.00x - 1.200 V)
P-State 3, FID 0x100 - VID 0x22 (4.00x - 1.125 V)
Attached device PCI device at bus 0, device 24, function 0
Attached device PCI device at bus 0, device 24, function 1
Attached device PCI device at bus 0, device 24, function 2
Attached device PCI device at bus 0, device 24, function 3
Attached device PCI device at bus 0, device 24, function 4
PERFEVT 803.0 MHz
Temperature 0 23 degC (73 degF) (Core #0)
Temperature 1 23 degC (73 degF) (Core #1)
Temperature 2 23 degC (73 degF) (Core #2)
Temperature 3 23 degC (73 degF) (Core #3)
Power 00 45.00 W (Package)
Clock Speed 0 803.54 MHz (Core #0)
Clock Speed 1 803.54 MHz (Core #1)
Clock Speed 2 803.54 MHz (Core #2)
Clock Speed 3 803.54 MHz (Core #3)
Core 0 max ratio 13.0 (effective 13.0)
Core 1 max ratio 13.0 (effective 13.0)
Core 2 max ratio 13.0 (effective 13.0)
Core 3 max ratio 13.0 (effective 13.0)
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
CPUID
0x00000000 0x00000005 0x68747541 0x444D4163 0x69746E65
0x00000001 0x00100F52 0x00040800 0x00802009 0x178BFBFF
0x00000002 0x00000000 0x00000000 0x00000000 0x00000000
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x00000000 0x00000000 0x00000000 0x00000000
0x00000005 0x00000040 0x00000040 0x00000003 0x00000000
0x80000000 0x8000001B 0x68747541 0x444D4163 0x69746E65
0x80000001 0x00100F52 0x10005146 0x000037FF 0xEFD3FBFF
0x80000002 0x20444D41 0x6C687441 0x74286E6F 0x4920296D
0x80000003 0x34582049 0x30323620 0x6F725020 0x73736563
0x80000004 0x0000726F 0x00000000 0x00000000 0x00000000
0x80000005 0xFF30FF10 0xFF30FF20 0x40020140 0x40020140
0x80000006 0x20800000 0x42004200 0x02008140 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x000001F9
0x80000008 0x00003030 0x00000000 0x00002003 0x00000000
0x80000009 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000A 0x00000001 0x00000040 0x00000000 0x0000000F
0x8000000B 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000D 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000E 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000F 0x00000000 0x00000000 0x00000000 0x00000000
0x80000010 0x00000000 0x00000000 0x00000000 0x00000000
0x80000011 0x00000000 0x00000000 0x00000000 0x00000000
0x80000012 0x00000000 0x00000000 0x00000000 0x00000000
0x80000013 0x00000000 0x00000000 0x00000000 0x00000000
0x80000014 0x00000000 0x00000000 0x00000000 0x00000000
0x80000015 0x00000000 0x00000000 0x00000000 0x00000000
0x80000016 0x00000000 0x00000000 0x00000000 0x00000000
0x80000017 0x00000000 0x00000000 0x00000000 0x00000000
0x80000018 0x00000000 0x00000000 0x00000000 0x00000000
0x80000019 0xF0300000 0x60100000 0x00000000 0x00000000
0x8000001A 0x00000003 0x00000000 0x00000000 0x00000000
0x8000001B 0x0000001F 0x00000000 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0xC0010114 0x00000000 0x00000018
MSR 0xC0010061 0x00000000 0x00000030
MSR 0xC0010062 0x00000000 0x00000003
MSR 0xC0010063 0x00000000 0x00000003
MSR 0xC0010064 0x800001B9 0x3C00180A
MSR 0xC0010065 0x80000193 0x3C002803
MSR 0xC0010066 0x80000186 0x3C00384C
MSR 0xC0010067 0x80000166 0x3C004440
MSR 0xC0010068 0x00000166 0x3C004440
MSR 0xC0010058 0x00000000 0xE0000001
MSR 0xC0010071 0x30B40063 0x3C034440
MSR 0xC0010015 0x00000000 0x01000010
MSR 0xC001001F 0x02586000 0x00000008
MSR 0xC0010070 0x00000000 0x3C034440
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 1, Thread ID 0
CPUID
0x00000001 0x00100F52 0x01040800 0x00802009 0x178BFBFF
MSR 0x0000001B 0x00000000 0xFEE00800
CPU Thread 2
APIC ID 3
Topology Processor ID 0, Core ID 3, Thread ID 0
CPUID
0x00000001 0x00100F52 0x03040800 0x00802009 0x178BFBFF
0 00 00 00 00
Description USB 2.0 Controller (EHCI)
Location bus 0 (0x00), device 19 (0x13), function 2 (0x02)
Common header
Vendor ID 0x1002
Model ID 0x4396
Revision ID 0x00
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x01
Latency 0x20
Header 0x00
PCI header
Address 0 (memory) 0xFE029000
Subvendor ID 0x1458
Subsystem ID 0x5004
Int. Line 0x13
Int. Pin 0x02
PCI capability
Caps class Power Management
Caps offset 0xC0
Caps version 1.1
PCI capability
Caps class Debug Port
Caps offset 0xE4
PCI registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 02 10 96 43 06 00 B0 02 00 20 03 0C 01 20 00 00
10 00 90 02 FE 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 58 14 04 50
30 00 00 00 00 C0 00 00 00 00 00 00 00 13 02 00 00
40
PCI header
Address 4 (port) 0x0000FA00
Subvendor ID 0x1458
Subsystem ID 0x5002
Int. Line 0xFF
Int. Pin 0x01
PCI capability
Caps class Message Signalled Interrupts
Caps offset 0x70
PCI registers
00 02 10 9C 43 05 00 30 02 00 8A 01 01 00 20 00 00
10 01 00 00 00 01 00 00 00 01 00 00 00 01 00 00 00
20 01 FA 00 00 00 00 00 00 00 00 00 00 58 14 02 50
30 00 00 00 00 70 00 00 00 00 00 00 00 FF 01 00 00
40 99 99 99 99 FF FF FF FF 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 40 26 10 2C 01 07 01 00 00 00 FF FF 0F 00
70 05 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Description Multimedia device
Location bus 0 (0x00), device 20 (0x14), function 2 (0x02)
Common header
Vendor ID 0x1002
Model ID 0x4383
Revision ID 0x00
PI 0x00
SubClass 0x03
BaseClass 0x04
Cache Line 0x01
Latency 0x20
Header 0x00
PCI header
Address 0 (memory) 0xFE024000
Subvendor ID 0x1458
Subsystem ID 0xA002
Int. Line 0x10
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.1
PCI registers
00 02 10 83 43 06 00 10 04 00 00 03 04 01 20 00 00
10 04 40 02 FE 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 58 14 02 A0
30 00 00 00 00 50 00 00 00 00 00 00 00 10 01 00 00
40 00 00 00 00 01 00 00 00 00 00 00 00 01 00 00 00
50 01 00 42 C8 00 00 00 00 00 00 00 00 00 00 00 00
60 05 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Description PCI to ISA Bridge
Location bus 0 (0x00), device 20 (0x14), function 3 (0x03)
Common header
Vendor ID 0x1002
Model ID 0x439D
Revision ID 0x00
PI 0x00
SubClass 0x01
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1002
Subsystem ID 0x439D
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 02 10 9D 43 0F 00 20 02 00 00 01 06 00 00 80 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 02 10 9D 43
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 04 00 00 00 D7 FF 03 FF 3F FF 40 00 00 00 00 00
60 00 00 00 00 00 0A 00 00 0E 00 0F 00 B8 FF FF FF
70 67 45 23 00 00 00 00 00 1C 00 00 00 05 0A 00 00
80 08 00 03 A8 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 08 01 00 00 00
A0 02 00 C1 FE 2F 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 E9 F2 FF 00 00
C0 00 00 00 00 00 00 08 00 F7 FF FF FD 00 00 00 78
D0 00 FF FF 00 00 00 00 FF FF FF FF 00 00 00 00 0C
Description PCI to PCI Bridge
Location bus 0 (0x00), device 20 (0x14), function 4 (0x04)
Common header
Vendor ID 0x1002
Model ID 0x4384
Revision ID 0x00
PI 0x01
SubClass 0x04
BaseClass 0x06
Cache Line 0x00
Latency 0x40
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x03
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 02 10 84 43 27 04 A0 02 00 01 04 06 00 40 81 00
10 00 00 00 00 00 00 00 00 00 03 03 40 C0 C0 80 22
20 C0 FD C0 FD B0 FD B0 FD 00 00 00 00 00 00 00 00
40 26 00 0C FF 00 00 00 00 0C 0F 3C D1 00 01 00 00
50 01 00 00 00 08 00 03 A8 00 00 00 00 85 00 FF FF
60 CA 0E 17 00 BA D8 10 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 01 00 02 06
E0 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00
Description USB Controller (OHCI)
Location bus 0 (0x00), device 20 (0x14), function 5 (0x05)
Common header
Vendor ID 0x1002
Model ID 0x4399
Revision ID 0x00
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x01
Latency 0x20
Header 0x00
PCI header
Address 0 (memory) 0xFE028000
Subvendor ID 0x1458
Subsystem ID 0x5004
Int. Line 0x12
Int. Pin 0x03
PCI registers
00 02 10 99 43 06 00 A0 02 00 10 03 0C 01 20 00 00
10 00 80 02 FE 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 12 03 00 00
40 80 01 00 00 11 00 00 00 00 00 00 00 00 00 00 00
50 40 13 1F F6 00 00 00 00 FF FF FF FF 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 FF 00 00 80 00 00 00 00 00 00 00 00
Description Host Bridge
Location bus 0 (0x00), device 24 (0x18), function 0 (0x00)
Common header
Vendor ID 0x1022
Model ID 0x1200
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps class HyperTransport
Caps offset 0x80
Caps revision 3.00
Interface type Host/Secondary
Device number 0
Link 0 width (in/out) 16 bits/16 bits
Link 0 frequency 2000 MHz
PCI registers
00 22 10 00 12 00 00 10 00 00 00 00 06 00 00 80 00
20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00
40 01 02 04 00 01 02 04 00 01 02 04 00 01 02 04 00
50 01 02 04 00 01 02 04 00 01 02 04 00 01 02 04 00
60 00 00 03 00 E0 00 00 00 20 A8 2E 01 00 F8 00 00
80 08 00 01 21 20 20 11 11 60 0B F5 8F 13 00 00 00
90 D0 02 85 80 00 00 03 00 07 00 00 00 00 00 00 00
Location bus 0 (0x00), device 24 (0x18), function 1 (0x01)
Common header
Vendor ID 0x1022
Model ID 0x1201
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 22 10 01 12 00 00 00 00 00 00 00 06 00 00 80 00
40 03 00 00 00 00 00 2F 01 00 00 00 00 01 00 00 00
50 MI Port Connector
designation PRIMARY IDE (internal)
connector On Board IDE
DMI Port Connector
designation FDD (internal)
port type 8251 FIFO Compatible
connector On Board Floppy
DMI Port Connector
designation COM1 (internal)
port type Serial Port 16450
connector 9 Pin Dual Inline (pin 10 cut)
connector DB-9 male
DMI Port Connector
designation LPT1 (internal)
port type Parallel Port ECP/EPP
connector DB-25 female
DMI Port Connector
designation Keyboard (internal)
port type Keyboard Port
connector PS/2
DMI Port Connector
designation PS/2 Mouse (internal)
designation No Detected (external)
port type Mouse Port
connector PS/2
connector PS/2
DMI Port Connector
designation USB (internal)
port type USB
connector Access Bus (USB)
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Extension Slot
designation PCI
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI Express x16
type A5
DMI Extension Slot
type A5
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 16 GB
max# of devices 4
DMI Memory Device
designation A0
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 2 GB
DMI Memory Device
designation A1
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 2 GB
DMI Memory Device
designation A2
format DIMM
type unknown
total width 64 bits
data width 64 bits
DMI Memory Device
designation A3
format DIMM
type unknown
total width 64 bits
data width 64 bits
Storage
Drive 0
Name WDC WD6400AAKS-00A7B0
Revision 01.03B01
Serial WD-WMASY2579070
Capacity 596.2 GB
Type Fixed
Bus Type ATA (3)
Features SMART
Volume c:\, 596.1 GBytes (51.0 percent available)
USB Devices
USB Device USB Input Device, class=0x00, subclass=0x00, vendor=0x192F, product=0x0416
USB Device USB Composite Device, class=0x00, subclass=0x00, vendor=0x04F2, product=0x0533
Graphics
Number of adapters 1
Graphic APIs
API ATI I/O
API ADL SDK
Display Adapters
Display adapter 0
ID 0x2060080
Name Standard VGA Graphics Adapter
Board Manufacturer GIGABYTE Technology
Codename RS880
Technology 55 nm
Memory size 512 MB
Memory bus width 32 bits
PCI device bus 1 (0x1), device 5 (0x5), function 0 (0x0)
Vendor ID 0x1002 (0x1458)
Model ID 0x9710 (0xD000)
Revision ID 0x0
Performance Level 0
Core clock 501.2 MHz
Win32_VideoController DriverVersion = 6.1.7600.16385
Win32_VideoController DriverDate = 06/21/2006
Monitor 0
Model WXGA TV ()
ID XXX0000
Serial
Manufacturing Date Week 6, Year 2012
Size 0.0 inches
Max Resolution 1360 x 768 @ 60 Hz
Horizontal Freq. Range 30-65 kHz
Vertical Freq. Range 50-76 Hz
Max Pixel Clock 110 MHz
Gamma Factor 2.2
Software
Windows Version Microsoft Windows 7 (6.1) Home Premium Edition 64-bit Service Pack 1 (Build 7601)
DirectX Version 11.0
Register Spaces
Register space PCI
Register space PCI #2
Register space PCI Express, base address = 0x0E0000000
Register space class = 0x12
Register space SMBus, base address = 0x0B00
Register space LPC, base address = 0x0228
Register space LPC, base address = 0x02E
Register space LPC, base address = 0x0CD0
___________________________________________________________________________________
CPU-Z TXT Report
Binaries
Processors
Number of sockets 1
Number of threads 4
APICs
Socket 0
-- Core 0 (ID 0)
-- Thread 0 0
-- Core 1 (ID 1)
-- Thread 1 1
-- Core 2 (ID 3)
-- Thread 2 3
-- Core 3 (ID 2)
-- Thread 3 2
Timers
Sys timer 1.000 KHz
Socket 1 ID = 0
Codename Propus
CPUID F.5.2
Extended CPUID 10.5
Brand ID 8
Core Stepping BL-C2
Technology 45 nm
FID/VID Control yes
Max VID 1.400 V
# of P-States 4
Package Type 0x1
Model 20
String 1 0xA
String 2 0x6
Page 0x0
CmpCap 4
ApicIdCoreSize 4
TDC Limit 76 Amps
Boosted P-States 0
Max CPU COF 26
What is your budget for this new purchase? You will also need to count on buying new DDR4 RAM since that is what most new processors use nowadays.
What is your primary use for this system?
Autocad
Photoshop
Internet
no games
3d studio max render
Thanks for the help Volkgren but can you answer the original question....what is the bottleneck device that is crippling mhz speeds on a system ? Is the the north bridge mobo or the Cpu stats? how would I identify this on internet product page stats? thx.
It appears you have 4 memory sticks installed? 2 of which are not being recognized. Or, you have 2 sticks installed and they are in the wrong slots.
It could be that you are using different types of memory modules. As I asked before, I need to know more details about your RAM. How many and what are the exact part numbers for all of your memory modules?
WE seem to be getting off topic. So I will give you your answer and thank you for your efforts while I look for my original answer else where.
I have two sticks both identical in every way. in slots one and two closest to the CPu. both slots colored blue while three and four are empty colored white.
Rendition 2 GB ddr2 240 256MX64 PC2-5
Thanks and Happy New year!
PC2-5...
that seems incomplete. The only PC2-5 is PC2-5300 which is DDR2 666. If that is what you have then your memory is running at full speed.
