I have this mobo: ASUS M5A99X Evo 2.0 AM3+ which takes a 20-1 (19 pin + a purposeful dud pin) & I'm attempting to use a TPM2.0-9665 20-1 module on it, which has worked for me on the P9X79 (Intel chipset released a year prior) but this one is giving me a problem!
I installed the module & when I go to the BIOS the TPM support can be enabled but there is a second option to enable the TPM State. It says to save the settings & reboot to make them stick but when I go back to the BIOS it keeps putting the TPM State back to disabled. The BIOS is the latest one from May 2014 that Asus provided.
UEFI is enabled + I attempted to temporarily disable secure boot, wiped the boot keys (after saving them to reload afterward) but nothing works. All Legacy settings were disabled but still nothing.
This gentlemen seems to have figured out which TPM is compatible with an AM3+ mobo: [ Thread from tulaneksig ]
I'm not able to continue that thread to ask its OP ( @tulaneksig ) which one he purchased.
Does anyone know of a 20-1 pin TPM 2.0 module that will specifically work with Asus AM3+ mobos (using DDR3 memory) from that era?
