problem with AMD FX 9590, it freezes
Sep 27, 2015
hi guys, i have a problem with my PC, it keep freezing like once every two days, i know is not a temperature problem, becasue every time it freezes the CPU temp is like in 30 degree celcius (86 degree Fahrenheit) i don't know exactly what is the problem here, i think its maybe the MOBO or the PSU but i'm not exactly an PC expert, just a amateur geek.
this is my rig:
AMD FX-9590 Vishera 8-Core 4.7 GHz Socket AM3+ 220W Black Edition
ASUS SABERTOOTH 990FX R2.0 AM3+ AMD 990FX
G.SKILL Ripjaws Series 8GB 240-Pin DDR3 SDRAM DDR3 1600
GIGABYTE GeForce GTX 970 GV-N970G1 GAMING-4GD 4GB 256-Bit GDDR5 PCI Express 3.0
EVGA 110-B2-0850-V1 80 PLUS Bronze 850 W Semi-Modular
and well, my cpu have a pre-build water cooling system
Corsair h100i with 4 corsair fans in the radiator
and well both, a SSD and a HDD
Kingston SSDNow V300 Series 2.5" 120GB SATA III
and a Seagate 2Tb HDD
like i said, i don't know exactly which is the problem, anyway i'm thinking on switch my MOBO to a better one... so please, if someone can help me i'll be very glad. THANKS
ok then, thank you so much, i will try to do that and see what happen, because actually just a few minutes ago it freeze again.
EDIT: already went to BIOS and disabled C6 and C1E cores, lets give it a try and see how it goes
Ok good luck.
WELL WELL, i just come with bad news... it just freeze again a couple minutes ago, i'm out of options, i'm start thinking very serious on buying a 1000+ PSU
Well yeah :/... i need to save a little bit of money to buy a 1000+ PSU and see if that can fix my problem, if don't i would be very sad and angry, anyway, thank you so much guys, you really help me a damn lot.. if some day i buy the PSU and it fix my problem, i will contact you to let you know
