G
Guest
Guest
Hi,
For at least the last 4 years I have been experiencing a very strange problem with the startup of my computer.
After pressing the on button on the case, the computer begins to run, but usually fails to boot the operating system properly during the first try. It freezes either at some point even before it begins to boot the system, or during the boot.
When I have luck (and it is currently the warmer season - read below), it even reaches a point where it resets itself at some point during the booting process.
This goes on and on (it takes normally one to five restarts) until the operating system gets properly booted.
I am using Windows XP and at first, I thought it would be connected somehow with the OS, but now I am almost sure it is not since, as I have said, the first hassle often begins even before the start of the booting process.
However, I am 97% certain it is connected with the temperature of the place the computer is in. When it is generally warmer, there is less of the hassle and the computer boots up properly faster (usually one minute) than when it is colder (4-5 minutes at most). Of course - we have the heating installed, but the computer is few centimetres near the outter wall, so the weather has some, although small, effect on the temperature at that place.
I am so certain with this observation because I have had already four years to prove it day by day and I do not remember it has ever failed.
I have tried to search the Internet for the solution, but this problem seems to be so uncommon that I have not found even a starting point from which I could move on, so I would be very grateful if you could provide me even with a reasonable clue.
My configuration is:
Motherboard: ASUS A7N8X-X (nForce 2 chipset)
CPU: AMD Athlon XP 1500+
Memory: 512 MB RAM (V-data)
Graphic card: ASUS V9560/TD (GeForce FX 5600)
