This is now my second motherboard of the same type, and the same problem has happened. The psu will run fine on its own with a tester, but once i plug it into the motherboard, it will not turn on. Also, the cpu socket doesn't look like it has any bent pins. I'm wondering if this is a problem with the connections themselves or if I just got two separate motherboards broken in shipping.
