[SOLVED] Problem with CPU temps
AlreadyZ
32
Hello guys. Recently i build my first Gaming PC. So everything went fine. But im afraid about my temps. The CPU is on 4.2 GHz, and 1.375V.
In Idle temp is around 39-40 degree.
Cinebench around 70-73 degree.
Aida64 Stresstest 60 degree.
And when Im playing COD Warzone on 1080p Ultra, im getting temps like 60-65 degree.
My Case is Matrexx 50 with 4 Fans, and my CPU Cooler is Artic Freezer 34 Duo.
Thank you :)
Thank you :)
Those temps sound fine, actually better than fine. If you are under 75C with stress you are in pretty good shape.
Thank you :)
Thank you :)
Those temps are good, if it is under 80 degrees under full load is perfectly fine.
