M mcle Honorable Feb 6, 2014 421 0 10,790 May 5, 2014 #1 i just brought a r9 280x gigabyte windforce oc and i have downloaded the oc guru and the display driver but it won't let me install direct x 9 it is blacked out thanks
Solution Vic 40 May 5, 2014 Go to the next site and download the latest drivers for your card, http://support.amd.com/us/gpudownload/Pages/index.aspx see if that works.
U unksol Splendid Sep 12, 2011 7,060 0 27,960 May 5, 2014 #2 why on earth are you trying to install directx9? it probably won't install because there's a more modern version already installed Upvote 0 Downvote
M mcle Honorable Feb 6, 2014 421 0 10,790 May 5, 2014 #3 i am confused as well but it came on the disc, should i go to their website? and if i should what do i do then? Upvote 0 Downvote
Vic 40 Titan Ambassador Oct 22, 2013 20,959 1,019 88,990 May 5, 2014 Solution #4 Go to the next site and download the latest drivers for your card, http://support.amd.com/us/gpudownload/Pages/index.aspx see if that works. Upvote 0 Downvote Solution
