Memory might be an issue if are odd timings, what CL are they? If not know then upload screenshot (use imgur) of spd tab in cpuz.
Ryzen likes even timings so you could try adjust manually instead of using docp automatic profile. You'll need to set dram voltage to 1.35v yourself and possibly soc voltage between 1.1 ~ 1.2v.
Ram slots also is important so they are best in 2nd and 4th slot from cpu.
If there is a Bios update for improved memory compatibility, i would also do that.
What IC means?Correct slots and timings are fine. Could be the ram isn't completely compatible, did think of that first when seeing the model name, lpx series hasn't played nice with Ryzen in the past. So either try manually adjust ram, update bios if applicable, or change ram for Gskill CL14 3200 (Samsung bdie), IC based ram Ryzen likes best.
I just build my PC. It's too bad that I have to buy new RAM for 3200The die chips on the ram pcb board.
Will try those too. Thanks a lot for the adviceI did suggest other workarounds and bios update suggestions, go back and review.
Didn't get what you said. What is command rate of t2?Yeah sure. Try command rate of 2t as well.
will try that too. You mean manually choosing 3000 and not enabling DOCP?I would try 3000 Mhz. You wouldn't be missing much vs 3200 Mhz. And turn Fast Boot off so the memory has a chance to train (your mobo sets timings for RAM, both seen and unseen, called Training).
I don't think there is a way to do that on Asus, it's either Auto (2133) or XMP/DOCP. So DOCP and select 3000 Mhz.will try that too. You mean manually choosing 3000 and not enabling DOCP?
