Question Problem with Focusrite Clarett+ 4Pre ?
Jul 28, 2024
Hi, I'm trying to connect my EP-133 K.O.II to FL Studio 24. I connected the Ko 2 with a 3.5 mm to 6.35 mm audio cable to my external audio interface, a Focusrite Clarett+ 4Pre. I have adjusted all the settings within my DAW, and a signal is recognized in the mixer, but no sound comes out of my speakers. I have also tried updating the Focusrite software (Focusrite Control) to the latest version, but still nothing. Then, I tried changing the audio interface and reconnected everything with my previous audio interface, which is the Presonus AudioBox USB96. I updated its software, adjusted all the settings in FL Studio, and when pressing play on the Ko2, everything works. How can I fix the problem with my Focusrite Clarett+ 4Pre (which is less than a year old)?
I managed to contact Focusrite and partly solved the problem, but now when I press play on the sampler, the audio comes out of the speakers, but I immediately noticed that some sounds are modified, The stereo sounds are fine, even too loud, while the mono sounds are almost imperceptible. What could be the problem?
