Hello, i'm gettin a little crazy here, pls help me outt
I've my main Pc, with a asus h110m-c/br motherboard, ethernet port supports gigabit ethernet, ok.
I'm using a modem/router provided by the network company. askey rtf3505vw-n2
My desktop was getting a gigantic bufferbloat in dslreports's upload phase..
So I noticed that my desktop was getting only 100mpbs connection, while my notebook was at 200 in 5g wifi.
hmm, weirdo. Figured out that my adapter speed was on 100mpbs, I was unable to change it.
I'm using a cheap cat 5e cable, with 5 meters from router to desktop.
Disconnected my ethernet cable from desktop and pluged in my notebook, getting 1gbps connection... hmmm
all my drivers are updated, windows fresh installer, tried without any drivers at all(fresh install windows), with the asus site, with the newest I could find.. and nothing seems to fix it.
I've tested my desktop with a ubuntu's liveUsb, if I could remember well, I was getting gigabit speed(but now I dont, even with ubuntu on desktop)
Is it possible that the EXACT same cable, while connected to my notebook detect a gigabit connection and when connected to my desktop detect only 100mpbs?? Is there another possible reason??
I just installed realtek ethernet diagnostic utility;
At the green ethernet option:
-Green feature status: ENABLE (impossible to turn it off)
-Saved (a full green bar) 5%
a line with 3 stages (disabled , stage1 and stage2) have a marker on stage 1
EST. Power in Normal case Giga 344 mW
100M 143mW
????? w*f does that even mean?
--- in the cable option
when I click it, immeadiatly the network goes down and back a little after,
shows
Link Speed: 100
pair length(m) Status
1-2 0 normal
3-6 0 normal
4-5 0 normal
7-8 0 normal
If i click in the refresh button, the same thing happens.
If i'm not mistaken, a while ago I was getting 2 at the length;
I've messed a lot in the meantime with the adapter properties, trying to fix it. Unluckly
aaaaaa i'm going to explode
Is it possible that my notebook connects to 1gbps by mistake and my router dont support it?
100M 143mW
shows
Link Speed: 100
1-2 0 normal
3-6 0 normal
4-5 0 normal
7-8 0 normal
