[SOLVED] Problem with gpu? Help
Mica888
23
I bought a new gpu hd 7850 2gb ddr5. I put it in my system and it runs fine. I get a massage that the new drivers are installed and that i should restart my pc. I do that and as soon as i turn it on my pc monitor wont turn on and says monitor going to sleep. But every coller is running but monitor wont turn on.
Before that i had r7 240 2gb ddr3 and it was running fine. Help
Specs:
Noname psu 500w
Cpu amd phenom x2 511
Ram 4gb ddr2
Motherboard Asrock n68c-s ucc
Its ok i fixed the problem. Everything was fine. The problem was in the dvid-vga connector l. Everytime i whould install drivers it whouldnt work for some reason. I randomly changed the adapter and put the dvi(24+5) and it worked.
