Problem with GTX 660
Areztristan
11
I just bought a HP envy 700 and I wanted to switch its GT 635 with my GTX 660,
when I put my 660 in the computer it wont power up or anything, but when I put the GT 635 in it turns on perfectly.
Hey friend, I found the solution to your problem. When I got home from work, I switched back to my GTX 660 from my 780. My screen didn't turn on either. What you have to do is uninstall the graphics drivers before you can update. This worked for me. Make sure you do this on safe mode.
Download this software first: http://www.guru3d.com/files_details/display_driver_uninstaller_download.html
Then boot up in safe mode and use this software to uninstall the drivers and...
I have a 625 watt PSU and Its it has a 6 pin connector
I used the GTX on my old pc 5 days ago and it worked fine, when I try to turn it on in this pc it just doesn't start
Then boot up in safe mode and use this software to uninstall the drivers and boot back up in the OS then install the updates!
