Problem with modem cisco DPC2203
totonaet
41
Hello. I have a problem with my modem, when I connect directly to it, you start seeing multiple failures such as loss of donwload and upload, random connection and disconnection of network cable, etc. But when I connect the modem to my router Tp link model: TL-740N and from there to my computer by Ethernet cable, the internet works well. Well, I want to connect my pc directly to the modem to get better performance in games and I can not. Someone help me pls? . Before I had windows 8 format and return to windows 7 and I still have the same error. I have installed the latest driver for my network card and when I do the test with the Internet through the router everything is fine. But when I do the modem everything is a mess. Thank you! Sorry for my grammar :)
In most cases this problem is related to MAC address registration. The IP address assigned by your ISP can only be registered to a single device. When you disconnect your router and connect your PC, your ISP is still looking for the router and will not allow access for the PC. You can usually solve this by rebooting the [strike]router [/strike]modem (and to be safe, reboot the PC). This allows the PC's MAC address to be registered against the IP address.
You'll need to do this each time you connect a different device directly to the modem.
Edited - corrected
So what do I do? Reboot the router to connect my pc directly to the modem ?? But in that case I would follow not connected to the router ?? Restarting the router then disconnect and bring it into the modem ??
Sorry, I meant "You can usually solve this by rebooting the modem..."
I reboot the Modem and pc an this is what happen
https://lh4.googleusercontent.com/-p3V-JfTvfTc/VGVtqXlEJbI/AAAAAAAAAIw/t_WO4tPykDU/w984-h553-no/lol.jpg
It´s say. There is no ethernet cable conected. And it was conected
