Hello , I have a problem with my pc if you can help me.
So , when i start the computer it stay 5-10 minutes and then reboot or blue screen , after that , pc wont start for 2-3 minutes , then i can start again , at the blue screen error it gives me Blue Screen error 1e.
My components are :
- Motherboard : MSI P35 Platinum Model : MS-7345 1.0 (BIOS VERSION 1.A)
- CPU : Intel Core 2 Quad Q6600 2.4Ghz , Stock , i didn't OC'ed.
- CPU Cooler : DeepCool I don't know the model but It's good. (CPU temp , around 45-50 - 55-60 in full load).
- GPU : Sapphire HD 4870 2gb Vapor-X 256 Bits GDDR5.
- Power Supply : Rasurbo GAP 656 650W
- RAM : 4x1gb Corsair XMS2 PC2 6400 800Mhz
- HDD : Maxtor 160GB SATA II (It's old , I have it from about 5-6 years , but is good , only 10 warnings in HD Tune).
EDIT: Sorry they are not errors just warnings about cable ...
My components are :
