I just bought ddr3 8gb ram 1600mhz but it cannot run on my pc which previously run on ddr3 2gb ram 1333mhz, every time I boot the blue screen appears.CPU-INTEL CORE I3
WINDOWS 10
WINDOWS 10
Did you check what RAM is supported? Also what version of windows are you running? 32 or 64 bit?I just bought ddr3 8gb ram 1600mhz but it cannot run on my pc which previously run on ddr3 2gb ram 1333mhz, every time I boot the blue screen appears.CPU-INTEL CORE I3
WINDOWS 10
Thanks a lot for replying.Did you check what RAM is supported? Also what version of windows are you running? 32 or 64 bit?
But does the board support 8GB sticks?Thanks a lot for replying.
My windows run on 64-bit windows 10.
And my pc supports 1333mhz but I knew the pc will automatically downclock the new 1600mhz ram for me
Pls yes my board support 8gb sticksBut does the board support 8GB sticks?
I support thisDid you take the old RAM out?
Google MemTest, it can test the new RAM without needing to load Windows.
Yes I took the old one out.Did you take the old RAM out?
By Google I mean search for MemTest, you will find it.Yes I took the old one out.
How do I do the Google mem test
OK tnx a lot I will do it tonight. If I have any problems I will notify you.After changing memory, I'd strongly recommend running memtest86 for 10+ hours to see if the memory might have issues. Any errors there would indicate a problem either with the memory chips themselves (errors that appear to affect specific bits at specific addresses) or the memory bus (errors follow a given address line or affect the same data bit(s) regardless of address.)
OH OK I will try downclocking my ram.You can't overclock locked Intel CPUs and I don't remember there being an unlocked i3 that uses DDR3. Downclocking the RAM is an option if you run into what you suspect to be RAM-related stability issues.
