G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Hi all!
I just got a 250GB Maxtor HD (6Y250P0) which I connected to the Ultra
DMA bus on my P4C800-Deluxe Asus mobo. I used the MaxBlast 3 software
by Maxtor to format the disk (didn't partition it), and downloaded the
Promise Fasttrak RAID drivers from the asus website and created the
driver disk that WinXP installation CD asks for after pressing F6.
Everything seems fine so far: the system copies files and warns to
take floppy out of the bay before rebooting.
Then the system reboots... and that's where my troubles start!
GUI starts, and it hangs right at the beginning of the installation
procedure, when it says "39 minutes left". The little dots at the
right bottom corner of the screen stop winding, i.e., the progress bar
stops, and the CD-ROM stops rotating. Basically, it stops reading
files and the system just hangs...
If I botton-reset the PC, GUI claims that installation process will be
reinitialized, but then an error message pops up warning that the
proceure could not be completed (too fast to spot the file name in the
left top corner that causes the problem). The system then reboots, and
that goes on and on and on and on...
(Additional note: after giving some more tries, now the system hangs even
before starting to copy files to the HD. Namely, it hangs when the "analysis
of 239xxGB on fasttrx2k in progress"...)
I have installed WinXP (BTW, the CD contains SP2) on the very same
system even if using a different HD (160GB by Maxtor) and attaching it
to the IDE controller.
Does anyone have any idea about the problem and the related solutions?
My kindest regards,
Nicola
Hi all!
My kindest regards,
Nicola
