Question Problem with PreBuilt
Jan 23, 2021
I recently bought a new prebuilt pc and it worked just fine when running games like league , however when trying to run something harder to run like ghost recon wildlands I get the problem where the game freezes and the pc restarts itself after a couple of minutes of playtime. the pc has a RTX2060 I7 2600 and 32gb of DDR3 Ram running on a 650W psu , I dont know much about newer pc components so any help would be appreciated
Jan 23, 2021
make and model of the psu?
cpu/gpu temp and usage during the game?
it that i7 2600? is this a used pc?
Bandit Power ATX650 80+ bronze certified the Cpu usage is 70%
Gpu Temp is 60degrees
Gpu usage is 95%
Cpu Temp is 80degrees
It is a i7 2600 , its not used I bought it new
Edit: Sometimes upon restarting the resolution changes and locks to 800x600 after which i need to uninstall my currect graphics drivers and reinstall them to fix it
DSzymborski
Polypheme
Also a fake 650W PSU with a forged badge.
If the 2600 came in a prebuilt, how do you know it was new?
In any case, if this is a new prebuilt, then the quickest resolution would be to contact the company who sold you the new prebuilt. New prebuilts come with warranties, after all.
