Hi,
So, I built my system about a month and half ago and everything has been running tip-top since I first turned it on. However, last week I added/installed a GPU and since then I get this strange issue when I turn on my computer.
Basically everything seems fine and the system boots to Windows just fine, and since the OS is on an SSD it usually boots in a matter of seconds. But every now and then when my desktop appears it's like it gets stuck. No weird stuff pops on the screen and it doesn't go BSOD, but I can't click stuff with my mouse and it won't let me use CtrlAltDelete. Basically, I have use the reset button or hard power it down and when it restarts I usually start it in safe mode and restart from that and everything seems to work fine, but every now and then I have to do that a couple times before it works correctly.
I need to let it run and figure out what that problem is, but I'm usually just sitting down for a minute when it happens and don't want to sit and wait. Anyone have an idea why it does this?
1-5 3570K|ASUS Z77-PRO | SAPPHIRE 7870 2GB OC | ANTEC TP 750W | SAMSUNG 830 128GB SSD | WD 500GB HDD | CM HYPER 212 EVO | PATRIOT RAM 2x4 1600MHZ | WINDOWS 7 PRO 64 BIT | LG OPTICAL DRIVE
