[SOLVED] Problem with TP link archer c60
bniknafs9
646
65
10,190
i have an archer c 60 connected as access point to my home network .
but it would frenquently go out with its internet light becoming orange , and no internet.
i don't have the same problem with either my linksys ea9500 or x3500 router / access points.
is it because i'm using a bad brand or i'm doing something wrong ?
also
can you help me set up VPN on my c60 ? pptp and l2tp are not working so far.
i want to do so so i can broadcast my vpn in my apartment .
yes as an access point
i put it on DHCP and set wifi password
If you have dhcp enabled, it's not an access point. And that's probably part of the problem.
Try these:
http://www.practicallynetworked.com/networking/convert_wifi_router_to_access_point.htm
Try these:
