[SOLVED] Problem with type C cable while charging.
aftab23.as
12
Greetings, when i connect my Nokia 5.1 plus to charger via type C cable, it does not works correctly at first. Sometime device shows that charging time is 11 hrs. When i remove and reconnect the cable and try to keep it untangled or straight to port it works but still it creates a lot problem. The charging port is fine. Please tell is there anything I should take care about Type C cable or anything. Or just that my cable is broken and I should buy new one. Would be glad if you helped. THANK YOU!
